Subject: Re: EPICS build on armv6l
To: [email protected]
Cc: Florian Feldbauer <[email protected]>
Date: Wed, 13 Jun 2012 10:58:29 -0500
Hi Florian & Tim,
On 2012-06-13 Florian Feldbauer wrote:
> worked for me too. Tim is right, you have to include
> $(CONFIG)/CONFIG.gnuCommon, too, in order
> to have the $(CC) and $(CCC) macros in the Makefiles
> defined.
Great.  The gnuCommon include should go in CONFIG.linux-arm.linux-arm to match
what happens with the linux-x86 target.  The CONFIG.linux-x86.linux-x86 file
also has a few settings associated with building static binaries and shared
libraries which might be needed on arm; I don't see anything in them that is
x86-specific, but I'm not sure it they're required or not.
Once we've worked out exactly what they should be I'll add these files to the
3.14 branch so they appear in the 3.14.12.3 release.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
EPICS build on armv6l Florian Feldbauer
RE: EPICS build on armv6l Tim Robinson
Re: EPICS build on armv6l Florian Feldbauer
Prev: how to start matlab script in MEDM Heiniger Martin
Next: streamdevice: error handling for multiple lines of input from one command Rock, Judith E.
Prev: Re: EPICS build on armv6l Florian Feldbauer
Next: RE: EPICS build on armv6l Tim Robinson
