Subject: RE: SynApps build error : win32-x86
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jun 2012 20:27:45 +0000
The tools are called dmake and gmake.  How are those conflicting, or is it something else in that folder?
Sent: Tuesday, June 26, 2012 3:05 PM
To: [email protected]
Cc: S. Stein; Mark Rivers
Subject: Re: SynApps build error : win32-x86
Hi S,
On 2012-06-26 S. Stein wrote:
> There is no "make" within strawberry/perl/bin:
Look in C:\strawberry\c\bin where the other tools are (I've just installed the
same version as you):
C:\strawberry>dir c\bin\*.exe
 Directory of C:\strawberry\c\bin
11/02/2011  11:56 AM           582,144 addr2line.exe
11/02/2011  11:56 AM           604,160 ar.exe
11/02/2011  11:56 AM         1,047,552 as.exe
11/02/2011  11:56 AM           215,552 c++.exe
11/02/2011  11:56 AM           581,120 c++filt.exe
11/02/2011  11:56 AM           214,016 cpp.exe
11/02/2011  11:56 AM           633,344 dlltool.exe
11/02/2011  11:56 AM            47,616 dllwrap.exe
01/10/2010  10:50 AM           135,898 dmake.exe
11/02/2011  11:56 AM            32,256 elfedit.exe
11/02/2011  11:56 AM           215,552 g++.exe
11/02/2011  11:56 AM           212,480 gcc.exe
11/02/2011  11:56 AM            36,864 gcov.exe
05/03/2011  02:42 AM           176,640 gmake.exe
11/02/2011  11:56 AM           642,048 gprof.exe
11/02/2011  11:56 AM           215,552 i686-w64-mingw32-c++.exe
11/02/2011  11:56 AM           215,552 i686-w64-mingw32-g++.exe
11/02/2011  11:56 AM           212,480 i686-w64-mingw32-gcc-4.4.7.exe
11/02/2011  11:56 AM           212,480 i686-w64-mingw32-gcc.exe
05/06/2011  01:52 AM            63,820 iconv.exe
11/02/2011  11:56 AM           846,848 ld.bfd.exe
11/02/2011  11:56 AM           846,848 ld.exe
11/02/2011  11:56 AM           592,384 nm.exe
11/02/2011  11:56 AM           734,720 objcopy.exe
11/02/2011  11:56 AM         1,102,848 objdump.exe
05/06/2011  01:52 AM           739,042 openssl.exe
03/03/2010  05:17 AM           101,888 patch.exe
01/10/2010  10:50 AM            38,626 pexports.exe
05/06/2011  11:56 AM            99,211 pg_config.exe
11/02/2011  11:56 AM           604,160 ranlib.exe
11/02/2011  11:56 AM           313,856 readelf.exe
11/02/2011  11:56 AM           583,680 size.exe
11/02/2011  11:56 AM           583,680 strings.exe
11/02/2011  11:56 AM           734,720 strip.exe
11/02/2011  11:56 AM           605,184 windmc.exe
11/02/2011  11:56 AM           687,616 windres.exe
05/06/2011  01:52 AM            43,295 xmlcatalog.exe
05/06/2011  01:52 AM           109,304 xmllint.exe
05/06/2011  01:52 AM            55,067 xsltproc.exe
              39 File(s)     15,720,103 bytes
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: SynApps build error : win32-x86 Andrew Johnson
Re: SynApps build error : win32-x86 S. Stein
Prev: Re: SynApps build error : win32-x86 Andrew Johnson
Next: Re: SynApps build error : win32-x86 Andrew Johnson
