Hi Zen,
With the asyn driver do you see the printf message, i.e. is the drvV792::rebootCb() function being called?
Perhaps the VME writes to disable interrupts are not actually being done because they are cached, and the cache is never flushed before the system shuts down. Have you declared ILEV and EVTR to be volatile? What happens if you do a read from those registers after the writes, which should flush the cache?
Sent: Wednesday, June 27, 2012 7:40 PM
To: Mark Rivers; Williams Jr., Ernest L.
Cc: [email protected]
Subject: epicsAtExit
Hi Mark,
I have a problem, which I have been ignoring for a while.
I have a device driver for a VME module based on asynPortDriver class. It is used with asyn R4.18, EPICS R3.14.12.2, vxWorks 6.6.
I have coded a couple of routines to disable interrupts when the IOC is shutdown (with CTRL-X), which does not work. Restarting the IOC which uses the asyn based driver with CTRL-X fails to come up. The IOC reaches some point in the booting sequence and then I suppose it crashes because the boot starts all over. I recover from that with a VME reset. Also, if I disable interrupts before rebooting all works fine.
I have created another device driver using the conventional approach, which does not use asyn. As far as I can tell most of the code if not the same is equivalent. With this device driver the interrupts get disabled on exit.
This is what I have in the asynPortDriver version of the device driver:
In the constructor I have:
epicsAtExit( rebootCbC,this);
then I have:
extern "C"{
static void rebootCbC( void* pvt){
drvV792* pthis=(drvV792*)pvt;
pthis->rebootCb();
void drvV792::rebootCb(){
printf( "%s::rebootCb: Interrupts disabled and Soft reset\n",dname);
fflush(stdout);
epicsThreadSleep(1.0);
_wtReg( ILEV,0);
_wtReg( EVTR,0);
Writing 0 to the EVTR disables interrupts. Also writing 0 to the ILEV register disables interrupts.
In fact, the same rebootCB code, seems to work fine in the non-asyn driver.
Is something subtle taking place because of vxWorks?
Can you offer suggestion on how to make it work?
Thanks in advance,
Zen
- Re: epicsAtExit Eric Norum
- RE: epicsAtExit Szalata, Zenon M.
- epicsAtExit Szalata, Zenon M.
回复: [SPAM] Re: Problems when download synApps IOC sunjl
Re: 回复: [SPAM] Re: Problems when download synApps IOC Dirk Zimoch
<2012>
2025
<2012>
2025
