1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: epicsAtExit
To: "Szalata, Zenon M." <[email protected]>
Date: Thu, 28 Jun 2012 14:24:47 -0500
Hi Zen,
On 2012-06-28 Szalata, Zenon M. wrote:
> Is it desirable
> to have the vxWorks routine sysAtReboot(), that is, how important it is? I
> could ask Ernest to include whatever needs to be included and rebuild
> vxWorks to have this routine available.
The advantage of having it is that vxWorks IOCs get to shut down their CA
other network connections nicely.  It might be essential with some badly-
written network attached devices though, I think there were some LAN-GPIB
devices that really needed it.  The rebootHookAdd() call that you're using is
fine if you only need to disable hardware interrupts, but by the time the
epicsAtExit() routines get to run the vxWorks network stack has been shut down
so the CA server and any Asyn network Port code can't close their sockets
properly.
> On the other hand, adding
> rebootHookAdd(epicsExitCallAtExits) to my st.cmd file fixes my immediate
> problem. Thank you again,
It sounds like you don't /need/ the sysAtReboot() code for your IOC, although
having it would remove the need for you to run that yourself.  If Ernest wants
to add it he can find out what to do here:
    http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: epicsAtExit Mark Rivers
epicsAtExit Szalata, Zenon M.
Re: epicsAtExit Andrew Johnson
RE: epicsAtExit Szalata, Zenon M.
Prev: RE: epicsAtExit Szalata, Zenon M.
Next: RE: epicsAtExit Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
