1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ethernet-based Gamma ion pump controller (mpc)
To: Jack <[email protected]>
Cc: [email protected]
Date: Fri, 29 Jun 2012 09:19:45 -0600
On 6/29/2012 1:15 AM, Jack wrote:
> If the checksum and setup are rights,
> did you try to cross the serial to Moxa cable ?
Sorry, I mixed this up a bit with a different ion pump controller the serial to ethernet card is a LANTRONIX card rather than a Moxa card. However, this is internal to the device, so I don't have access to the serial cable.
This is a Digitel MPC pump.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
ethernet-based Gamma ion pump controller (mpc) Scott Baily
Re: ethernet-based Gamma ion pump controller (mpc) Jack
Prev: Re: ethernet-based Gamma ion pump controller (mpc) Wesley Moore
Next: Re: SynApps build error : win32-x86 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ethernet-based Gamma ion pump controller (mpc) Pavel Masloff
Next: Re: ethernet-based Gamma ion pump controller (mpc) Wesley Moore
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
