Subject: Re: ethernet-based Gamma ion pump controller (mpc)
To: Wesley Moore <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 03 Jul 2012 12:45:38 -0600
We've managed to resolve the issue. The mpc pumps just use a serial to ethernet adapter, so the protocol is identical to the serial protocol. I recently learned that these controllers will accept packets with a checksum of 00, so it's not required to calculate the checksum. Also they should report error messages for checksum errors or invalid commands (as long as the address field is correct). However, our particular version has both a serial port and an ethernet port. The internal dip switches were set at the factory for RS-485 operation rather than ethernet communication. After modifying the dip switches we have ethernet communications working well.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
Re: ethernet-based Gamma ion pump controller (mpc) Wesley Moore
Prev: Re: multi caput/get Gerrit Kühn
Next: caQtDM - getting not a valid Qt plugin error messages Jimmy Johnson
Prev: Re: ethernet-based Gamma ion pump controller (mpc) Wesley Moore
Next: iptables example script for EPICS CA Mark Rivers
