Subject: Re: EDM Segmentation fault
To: <[email protected]>
Date: Thu, 12 Jul 2012 15:53:34 +0200
On Thursday, July 12, 2012, Zhang Yuliang wrote:
> Hello all,
> I am trying to install EDM-1-12-78 on a Redhat 4.8 32 bit machine and am
> able to build it successfully. However, when I try to create a new edl
> file or open an existing edl file , the EDM crashes with the error of
> "Segmentation fault".
> How to solve this issue?
The very first thing is to inlcude the author (John William Sinclair
<[email protected]>), as I believe he does not listen to tech-talk for bug
reports.
Then, make sure a core file gets generated. If not, enable this by issuing
the command
> ulimit -c unlimited
on the shell before starting edm. Now, load edm (the executable) into a
debugger (I use ddd as frontend to gdb), let it crash, load the core file,
ask ddd to let you see the stack backtrace. Post this backtrace.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: EDM Segmentation fault Benjamin Franksen
EDM Segmentation fault Zhang Yuliang
Prev: EDM Segmentation fault Zhang Yuliang
Next: Re: EDM Segmentation fault Benjamin Franksen
