Subject: Re: stream device string/hex parsing
To: Gerrit Kühn <[email protected]>
Cc: [email protected], [email protected]
Date: Thu, 26 Jul 2012 17:55:55 +0200
Hi Gerrit,
I would not use extrainput=Ignore except when absolutely necessary, because this may hide some errors with incomplete input strings (e.g. because of bad connections).
Better ignore a known number of digits after your payload like
%*5c%4x%*30x
Even better do not ignore the checksum but check it. What is the checksum algorithm? (sum of all bytes)&0xff as 2 hex digits? See the %<> formats.
Dirk
Gerrit Kühn wrote:
On Mon, 9 Jul 2012 17:19:25 +0000 <[email protected]> wrote about RE:
stream device string/hex parsing:
Peter,
POAU> Have you set
POAU> extrainput = Ignore; POAU> In your protocol file?
No, I did not recognize that this was needed, because matching %4c instead
of %4x worked fine.
But you are right, extrainput=ignore fixed the issue, also matching the
rest of the string by %s makes it work. Thanks!
POAU> Even so a better strategy would be to use redirection:
Yes, that's already on my list of improvements to try out. I just wanted
to get the "most simple" solution to work first, before trying something
more sophisticated. Anyway, thanks for the hint.
cu
  Gerrit
Re: stream device string/hex parsing Gerrit Kühn
RE: stream device string/hex parsing peter.owens
Prev: RE: asynPortDriver Szalata, Zenon M.
Next: waveform display John Dobbins
Prev: Re: stream device string/hex parsing Gerrit Kühn
Next: Re: stream device string/hex parsing Gerrit Kühn
