Subject: Re: Waveform read problems
To: Eric Norum <[email protected]>
Cc: "[email protected] tech-talk" <[email protected]>
Date: Mon, 30 Jul 2012 13:57:42 -0700 (PDT)
Hey guys,
Thanks for all your help and advice. Using gdb I found my problem was not assigning the appropriate amount of memory to copy the record msg char* into a buffer char*. I fixed this by just accessing the record msg directly without copying it. Attached below is the custom conversion routine I found works well and reliably.
 // WF read routine for AGE5071C, converts Hz to MHz for P1==1
static int readWF(struct gpibDpvt *pdpvt,int P1, int P2, char**P3) {
  struct waveformRecord *pwf=(struct waveformRecord *)pdpvt->precord;
  asynUser *pasynUser = pdpvt->pasynUser;
  double* value = (double *)pwf->bptr;
  double data;
  int n;
  pwf->nord=0;
  while ((pwf->nord < pwf->nelm) && sscanf(pdpvt->msg,"%lE,%n",&data,&n)==1) {
    if (P1==1) data/=1E6;
    memcpy(value+pwf->nord,&data,sizeof(double));
    pwf->nord++;
    pdpvt->msg+=n;
    asynPrint(pasynUser,ASYN_TRACE_FLOW,"(NORD,VAL) : (%i,%E)\n",pwf->nord,data);
  if (pwf->nord == 0) return -1;
  pwf->udf = 0;
  return 0;
I can definitely see now the the advantages of using stream device. I my system control needs become more complicated I'll switch over to using that instead of asynGpib.
Cheers,
Andrew
On Mon, 30 Jul 2012, Eric Norum wrote:
I put together a simple StreamDevice/ASYN application and a small python script to provide a dummy 'instrument'.   The instrument provides 30000 values on demand.
Things seem to work as expected.  Here's the output from the final command of the startup script:
dbpr "wchk:1:Wave"
ASG:                BUSY: 0             DESC: Read a long waveform
DISA: 0             DISP: 0             DISV: 1             NAME: wchk:1:Wave
NORD: 30000         SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
VAL: 0x0
As you can see, the IOC has successfully read 30000 double values from the instrument.
Andrew -- perhaps you can massage the attached application a little to match the commands of your hardware and see if things work for you as well?
Re: Waveform read problems Eric Norum
Prev: Re: Waveform read problems Eric Norum
Next: Re: Waveform read problems Eric Norum
