1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Problem with the basic example
To: [email protected]
Date: Tue, 31 Jul 2012 11:52:54 -0500
On 2012-07-31 Ralph Lange wrote:
> Shouldn't the db parser complain about this?
It should print a warning, but we haven't been very strict about the set of
allowed characters in the past so I don't think 3.14.x can reject all of the
characters that fall outside the set that is documented as legal.  I'll add
code to warn about space, both quotes, dot and dollar — any others that I
should add to that (fairly arbitrary) list?
The real bug here though is that makeBaseApp.pl should have removed the dot
and any other illegal characters from the user-name when it instantiated the
example template in the first place.  Bruno's generated example should never
have tried to create record names with dots in them at all.
Both fixes are almost ready to commit to the 3.14 branch.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Problem with the basic example Benjamin Franksen
Re: Problem with the basic example Ned Arnold
Re: Problem with the basic example Ralph Lange
Prev: Re: Problem with the basic example Benjamin Franksen
Next: Re: Problem with the basic example Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Problem with the basic example Ralph Lange
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
