Subject: Cross-compilation, static build, etc
To: [email protected]
Date: Thu, 2 Aug 2012 09:32:31 -0300
Hi
I'm back =) I'm having a problem deploying an IOC that I developed. I'm using a 64-bits Linux box as a host and I want to target a 32-bits Linux box. EPICS build system compiles my 32-bits executable just fine, but when I try to run it in my 32-bits box (without any EPICS software whatsoever), I get errors. Specifically:
/lib/libc.so.6: version 'GLIBC_2.15' not found (required by lib/libCom.o)
Obviously, I have a version problem regarding the GLIBC: the host's version is 2.15 and the target's is 2.7. Investigating further on, the culprit is a symbol inside libCom.so:
$ objdump -T libCom.so | fgrep GLIBC_2.15
00000000      DF *UND* 00000000  GLIBC_2.15  __fdelt_chk
This is the only symbol that requires GLIBC 2.15. I looked at other symbols from libCom.so and from other EPICS shared objects and it seemed that they required versions below 2.5, which my target's GLIBC 2.7 could handle nicely.
Nevertheless, I looked around for solutions:
1. Upgrade GLIBC version in the target
The Linux distribution used does not provide an easy way to do so. The highest version I found easily available was 2.9. If all else fails, I might try this again. I would like to stick with this distribution, if possible.
2. Downgrade host's GLIBC
I'm using Ubuntu. It seems a long gap between 2.7 and 2.15 versions of GLIBC, so I couldn't find a package to just 'apt-get' it. Again, I might investigate this further if no other solution comes around.
3. Copy my host's GLIBC into my target
That was a long shot. Didn't work.
4. Static build my IOC
That is the option I like the best. Ideally I would want to just compile everything into an executable, drop that executable in my target box and then run it.  Seems that a statically buily executable would nicely fulfill that purpose. I really don't care about the file size.
I'm not familiar with the EPICS build system, so I tried to statically build my IOC by just adding 'LDFLAGS= -static' to my Makefile. This produced scary warnings and a million errors about the linker not finding pthread symbols.
Then I tried to put a 'STATIC_BUILD=YES' somewhere, but didn't know where exactly. I decided to put it in my application's configure/CONFIG_SITE. After I ran make again, the only difference I noted was the addition of '-Bstatic' to the g++ flags.
According to the manual (man g++):
VxWorks Options
       The options in this section are defined for all VxWorks targets.  Options specific to the target hardware are listed with the other options for
       that target.
       -Bstatic
       -Bdynamic
           These options are passed down to the linker.  They are defined for compatibility with Diab.
Well, my target definitely isn't VxWorks...
So, finally, my questions:
Is it possible to make a static build of an IOC for x86 from a 64bits host? I searched EPICS documentation, but without much success...
Are there other solutions/alternatives? Maybe (most likely) I'm missing something here...
Thanks in advance!
Bruno Seiva Martins
RE: Cross-compilation, static build, etc Mark Rivers
Prev: How to scale waveform of integers to float? Benjamin Franksen
Next: Re: How to scale waveform of integers to float? Dirk Zimoch
Prev: Re: How to scale waveform of integers to float? Dirk Zimoch
Next: RE: Cross-compilation, static build, etc Mark Rivers
