Hi all,
I get some compiler warnings when compiling 3.15.0.1. This is a
collection of warnings from several different compilers. Not all
compilers show all warnings.
epicsTempFile.o: In function `epicsTempName':
/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.SL6-x86_64/../../../src/libCom/osi/os/posix/epicsTempFile.cpp:23:
warning: the use of `tmpnam' is dangerous, better use `mkstemp'
man tmpnam says:
Although tmpnam(3) generates names that are difficult to guess,
it is nevertheless possible that between the
time that tmpnam(3) returns a pathname, and the time that the
program opens it, another program might create
that pathname using open(2), or create it as a symbolic link.
This can lead to security holes. To avoid
such possibilities, use the open(2) O_EXCL flag to open the
pathname. Or better yet, use mkstemp(3) or tmp-
file(3).
BUGS
Never use this function. Use mkstemp(3) or tmpfile(3) instead.
The function epicsTempName() is used only twice, both times directly
followed by open(): in flex.c and in truncateFile.c. I suggest to modify
this code to use epicsTempFile() instead (if possible) and to drop
epicsTempName().
../../../../../../src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc: In
member function ‘virtual bufSizeT casDGIntfIO::osSendBufferSize() const’:
../../../../../../src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc:515:
warning: comparison between signed and unsigned integer expressions
../../../../../../src/ca/legacy/pcas/io/bsdSocket/casStreamIO.cc: In
constructor ‘casStreamIO::casStreamIO(caServerI&,
clientBufMemoryManager&, const ioArgsToNewStreamIO&)’:
../../../../../../src/ca/legacy/pcas/io/bsdSocket/casStreamIO.cc:107:
In both cases, an int variable (as required by getsockopt) is compared
to an unsigned int constant (the macros MAX_UDP_SEND and MAX_TCP)
A simple cast helps:
if ( size <= (int) MAX_UDP_SEND ) {
and
if ( size <= (int) MAX_TCP ) {
../../../src/ioc/db/dbBkpt.c: In function ‘dbp’:
../../../src/ioc/db/dbBkpt.c:821: warning: ‘precord’ may be used
uninitialized in this function
precord cannot really be used uninitialized here, but initializing it to
NULL removes the warning.
../../../src/libCom/error/errlog.c: In function 'errlogPrintf':
../../../src/libCom/error/errlog.c:109: warning: 'nchar' may be used
Here some compilers are not clever enough to see that this cannot
happen. Initializing nchar to 0 helps.
../../../../../../src/ca/legacy/pcas/generic/casDGClient.cc: In member
function 'caStatus casDGClient::searchFailResponse(const caHdrLargeArray*)':
../../../../../../src/ca/legacy/pcas/generic/casDGClient.cc:351:7:
warning: variable 'status' set but not used [-Wunused-but-set-variable]
The return value of this->out.copyInHeader() is stored in status but not
used. The function always succeeds (is this correct?). As it is now, the
status variable can be removed.
../../../src/libCom/osi/os/vxWorks/osdFindSymbol.c: In function
`epicsLoadLibrary':
../../../src/libCom/osi/os/vxWorks/osdFindSymbol.c:48: warning: implicit
declaration of function `close'
vxWorks declares close() in ioLib.h
../../../src/libCom/osi/os/default/epicsReadline.c: In function
`epicsReadlineBegin':
../../../src/libCom/osi/os/default/epicsReadline.c:215: warning:
assignment makes integer from pointer without a cast
`epicsReadline':
../../../src/libCom/osi/os/default/epicsReadline.c:240: warning: passing
arg 1 of `ledRead' makes pointer from integer without a cast
`epicsReadlineEnd':
../../../src/libCom/osi/os/default/epicsReadline.c:266: warning: passing
arg 1 of `ledClose' makes pointer from integer without a cast
The data type of ledId has changed. In vxWorks 5 it is int, in vxWorks 6
it is LED_ID (a typedef for struct led *). The return value of ledOpen
in case of a failure is (LED_ID)ERROR.
epicsReadline.c can be changed to use LED_ID instead of int for ledId.
To make LED_ID available for earlier vxWorks versions create a macro:
(_WRS_VXWORKS_MAJOR is not defined in vxWorks 5 or earlier).
#ifndef _WRS_VXWORKS_MAJOR
#define LED_ID int
#endif
../../../src/ioc/db/dbNotify.c: In function `dbNotifyDump':
../../../src/ioc/db/dbNotify.c:609: warning: `lockStatus' might be used
The vxWorks 5 compiler does not recognize that this cannot happen.
Anyway, initializing lockStatus to epicsMutexLockError helps.
../../../src/libCom/osi/os/vxWorks/veclist.c: In function 'veclist':
../../../src/libCom/osi/os/vxWorks/veclist.c:95: warning:
'symFindByValue' is deprecated (declared at
/afs/psi.ch/project/vxworks/WindRiverGPP3.7/vxworks-6.7/target/h/symLib.h:119)
In vxWorks 6, symFindByValue is deprecated. use symByValueFind() instead.
Dirk
- EPICS Base version 3.15.0.1 released Andrew Johnson
Re: OPC with binary out records Carsten Winkler
Re: EPICS Base version 3.15.0.1 released Tim Mooney
<2012>
2025
Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Matlab choices S. Stein
<2012>
2025
