1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Creating INLINK/OUTLINK in record support
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Thu, 23 Aug 2012 17:21:48 -0500 (CDT)
Hi Dehong,
Well, there is recDynLink, which provided retargetable links for the scan record, back in the days before all EPICS links became retargetable.  I think I would be wary of using recDynLink in new code, because it uses unpublished resources from base.
What's the problem you're trying to avoid with having link fields in the .dbd file?
Is it that you don't know in advance how many links you'll need?
Tim
----- Original Message -----
To: [email protected]
Sent: Thursday, August 23, 2012 3:19:49 PM
Subject: Creating INLINK/OUTLINK in record support
Is it possible to create these things dynamically inside a record, so that
I can access PVs on another IOC, without listing them all in the dbd file of
my custom record?
In other words, is there something like the
dbNameToAddr
to use for creating and accessing LINKs?
Thanks and best regards,
Dehong
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Creating INLINK/OUTLINK in record support Zhang, Dehong
Prev: Re: Creating INLINK/OUTLINK in record support Andrew Johnson
Next: Re: Motor Record 6-5-2 backlash issue? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Mass PV assign and event flag sync [was: Creating INLINK/OUTLINK in record support] Andrew Johnson
Next: Problem with medmfonts.ali running under Ubuntu 1204 Ivan
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
