Well, it may be, "the top Google result for "epics record reference".", but it's still wrong.
Here's the code itself. static void convert(aiRecord *prec) { double val;
val = (double)prec->rval + (double)prec->roff; /* adjust slope and offset */ if(prec->aslo!=0.0) val*=prec->aslo; val+=prec->aoff;
/* convert raw to engineering units and signal units */ switch (prec->linr) { case menuConvertNO_CONVERSION: break; /* do nothing*/
case menuConvertLINEAR: case menuConvertSLOPE: val = (val * prec->eslo) + prec->eoff; break;
default: /* must use breakpoint table */ if (cvtRawToEngBpt(&val,prec->linr,prec->init,(void *)&prec->pbrk,&prec->lbrk)!=0) { recGblSetSevr(prec,SOFT_ALARM,MAJOR_ALARM); } }
Hi Eric,
I believe you refer to [1]. I was referring to the text that I found in [2], which is the top Google result for "epics record reference". Those texts present different formulas:
[1] val = val * ESLO + EGUL [2] val = val * ESLO + EOFF
So there seems to be an inconsistency in the documentation. I'll try to set both EOFF and EGUL, as Ralph suggested.
Thanks!
Bruno Seiva Martins
On Tue, Aug 28, 2012 at 10:45 AM, Eric Norum <[email protected]> wrote:
Perhaps you misread the wiki page. EGUL does not take part in the conversions.
Here is the salient portion of the wiki page:
The record processing routine performs the following algorithm for all records except those that use the Soft Channel device support routine. Be aware that step 3 is performed only when the record specifies LINEAR:
- 1. Val= RVAL + ROFF
- 2. Val = Val * ASLO + AOFF
If the conversion algorithm is LINEAR, the raw value is converted via the equation: - 3. val = val * ESLO + EOFF
If the conversion is via a breakpoint table, the new value is obtained.
Hi all,
I am having trouble trying to adjust the conversion parameters of an analog input record for a A/D converter. My AD accepts voltages ranging from -10 to 10 volts and has a resolution of 12 bits.
For -10 volts, it produces a digital output of 0 For 10 volts, 4095
I configured the conversion fields as follows:
EGUF: 10
EGUL: -10 AOFF: 0 ASLO: 1 EOFF: 0 ESLO 0.004884 // which is (EGUF - EGUL) / 4095
ROFF: 0 LINR: LINEAR
Those values seem right to me but, for example, RVAL=1005 gets converted to VAL=4.9084, when it should be VAL=-5.0916. The problem seems to be that the conversion formula isn't taking into account the EGUL field.
According to the EPICS record reference for aiRecord:
1. Val= RVAL + ROFF 2. Val = Val * ASLO + AOFF If the conversion algorithm is LINEAR , the raw value is converted via the equation:
3. val = val * ESLO + EGUL
Seems like the step 3 is not being completely executed, or considering EGUL = 0...
Does anybody know what is wrong? Probably I'm missing something really obvious, but I couldn't figure it out...
Thanks in advance,
Bruno Seiva Martins
- Re: aiRecord conversion Ralph Lange
- aiRecord conversion Bruno Seiva Martins
- Re: aiRecord conversion Eric Norum
- Re: aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Dirk Zimoch
<2012>
2025
<2012>
2025
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
