1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: aiRecord conversion
Cc: [email protected]
Date: Tue, 28 Aug 2012 11:30:00 -0700
The problem is that a google search bypasses that top page -- a google search for 'epics ai record' produces
  1. Chapter 4: ai--Analog Input
    www.aps.anl.gov/epics/EpicsDocumentation/.../RecordRef/Recordref-...
    EPICS Record Reference Manual ... The analog input record has the standard fields for specifying under what circumstances the record will be processed.
  2. EPICS Re: soft device for ai record works as sscanf.
    www.aps.anl.gov/epics/tech-talk/2009/msg00311.php
    Feb 24, 2009 – EPICS Re: soft device for ai record works as sscanf.
  3. EPICS Record Reference Manual
    Record Reference Manual ... EPICS Release 3.13 ... Chapter 3: - Fields Common to Many Record Types · Chapter 4: - ai--Analog Input · Chapter 5: - ao - Analog ...
  4. EPICS Analog Input records, Stream Device, and INVALID Alarms
    www.aps.anl.gov/epics/tech-talk/2010/msg00416.php
    Apr 15, 2010 – I have a database that communicates via RS-232 to a vacuum gauge controller. I do this by setting up an Analog In record, that has the DTYP ...
Clicking on the link provided as the first hit takes you to the ancient page -- with no warning that it's totally out of date.
The safest approach IMHO is to take that old stuff completely off the web server -- or at least add the magic to tell google's crawlers not to index it.
On Aug 28, 2012, at 11:12 AM, Andrew Johnson <[email protected]> wrote:
Hi Eric,
On 2012-08-28 Eric Norum wrote:
Maybe, but the fact that it seems to be showing up as the top google hit is
a matter of concern, I think. Proof by example -- it's clearly already
tripped up one new developer. I really (note, no yelling this time  :-) )
think that the ancient documentation should be expunged.
I have added some text to that title page directing people to the Wiki for
updated versions.
…..snip…...
Eric Norum
[email protected]
Re: aiRecord conversion Andrew Johnson
aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Ralph Lange
Re: aiRecord conversion Eric Norum
Prev: Re: aiRecord conversion Andrew Johnson
Next: Re: aiRecord conversion Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
