1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: put to disabled records and monitors
To: [email protected]
Date: Fri, 31 Aug 2012 11:21:29 -0500
Hi Dirk,
On 2012-08-31 Dirk Zimoch wrote:
> Tim Mooney wrote:
> > By the way, you can do a more thorough job of disabling a record by
> > writing 1 to DISP ("Disable putField"), in addition to disabling
> > processing via SDIS or DISA.  (But note that DISP==1 means you can't
> > write to the DISA field, so you have to write to DISA, DISP, DISA in that
> > order.)
> That's the opposite of what we need :-)
> The record has to be configured before it starts its work. That means
> putting values to several fields (VAL and others).
Tim has explained that the behavior that's coded into dbPut() (although
possibly not ideal) is necessary for the design we have at the moment.  Can
you configure the EPID to fetch its setpoint through STPL from another record
which is the one the user actually sets?
I think the fundamental problem is that the epid.VAL field is being used as an
input, whereas the dbPut() design was really for VAL as an output.  The
easiest fix might be to add another field (say STPT) that can be used to give
the epid it's set-point, mark as VAL SPC_NOMOD and copy STPT to VAL whenever
the record is processed with SMSL set to Supervisory (when STPL is not used).
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: put to disabled records and monitors Pal Trivan
Re: put to disabled records and monitors Tim Mooney
Re: put to disabled records and monitors Dirk Zimoch
Prev: Re: retrun value (thread id) for seq() Benjamin Franksen
Next: modbus R2-4 write 32bit int with modbus function 16 Fabian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: put to disabled records and monitors Dirk Zimoch
Next: RE: put to disabled records and monitors Pal Trivan
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
