1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: edm and other extensions on 64-bit SL machines
To: "'Pierrick Hanlet'" <[email protected]>, Tech Talk <[email protected]>
Date: Fri, 31 Aug 2012 21:18:40 +0000
You need to set EPICS_HOST_ARCH to linux-x86_64 so that you are building a 64-bit application, not a 32-bit application.
You also need to make sure you have installed the openMotif package, which many newer Linux distributions do not include by default.
From: [email protected] [mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Friday, August 31, 2012 4:06 PM
To: Tech Talk
Subject: edm and other extensions on 64-bit SL machines
I'm using 3.14.12 on a 64-bit Scientific Linux machine.  I'm attempting to build extensions
such as edm, but always fail when the linker asks for libraries such as libXm, etc.  The
message states that it is searching for the libraries in /usr/lib, but as a 64-bit machine,
these libraries are in /usr/lib64.  I've searched tech-talk archives, but have been unsuccessful
in finding what switch (flag) I need to set to force it to link to the correct libraries.  Would
someone kindly point me in the right direction?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Re: edm and other extensions on 64-bit SL machines Jennings Guy
edm and other extensions on 64-bit SL machines Pierrick Hanlet
Prev: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Next: Re: edm and other extensions on 64-bit SL machines Jennings Guy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
