Excellent!
Mille grazie. Pierrick Sent from my Verizon Wireless Phone ----- Reply message -----
From: "Janet Anderson" <[email protected]> To: "[email protected]" <[email protected]> Subject: edm and other extensions on 64-bit SL machines Date: Tue, Sep 4, 2012 11:56 Hi Pierrick,
I put a new version of the extensionsTop tar file on the EPICS extensions/configure/ web page. This version has the 64 bit paths. Janet On 08/31/2012 05:49 PM, Pierrick Hanlet wrote: > Hi Andrew, > This appears to be the problem. > There is nothing in the file other than the -include > $(TOP)/configure/os/CONFIG_SITE.linux-x86.linux-x86; > so it points to the the 32-bit varieties. > Thank you, > Pierrick > > On 08/31/2012 05:45 PM, Andrew Johnson wrote: >> Hi Pierrick, >> >> On 2012-08-31 Pierrick Hanlet wrote: >>> Both edm and alh require libXm (and perhaps others of that suite). Each >>> fail to build with >>> the error: >>> No rule to make target `/usr/lib/libXm.a'. >>> This tells me that it searched and expects to find the library in >>> /usr/lib. If I understand things >>> correctly, should it not be searching in /usr/lib64 since that is where >>> the libraries reside? >> Take a look at the file >> extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 >> which should set those paths for you. >> >> - Andrew > > -- > "Whether you think you can or think you can't, either way, you are correct" -- > Henry Ford > _______________________________________________________________ > *Pierrick Hanlet* > IIT/Fermilab > +1-630-840-5555 (FNAL) > +1-312-567-5745 (IIT) > +1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
ANJ, 18 Nov 2013 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
