This problem can be solved changing the 'configure' parameters. From Norum's guide:
2. Configure RTEMS for your target architecture: cd /usr/local/rtems-4.9.2/build
.../rtems-4.9.2/configure --target=powerpc-rtems4.9.2 \ --prefix=/usr/local/rtems/rtems-4.9.2 \ --enable-cxx --enable-rdbg --disable-tests --enable-networking \ --enable-posix --enable-rtemsbsp=mvme2100 \
If you change '--disable-tests' to '--enable-tests', apparently those missing *.rel files get created and the compilation process go on.
Bruno Seiva Martins
On Wed, Sep 5, 2012 at 8:45 AM, Bruno Seiva Martins <[email protected]> wrote:
Hi All,
I was trying to compile EPICS base for RTEMS, but the compilation process stopped with those errors:
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-dpmem.rel: Arquivo ou diretório não encontrado
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-mp.rel: Arquivo ou diretório não encontrado i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-part.rel: Arquivo ou diretório não encontrado
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-signal.rel: Arquivo ou diretório não encontrado i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-rtmon.rel: Arquivo ou diretório não encontrado
The error message means "File or folder not found". I came across a thread that describes a similar problem:
But, unlike the author of the thread, I have nowhere to copy those files from. I was following Norum's guide "Getting started with EPICS on RTEMS". I built everything from source, including the toolchain for RTEMS, some libraries and RTEMS itself.
Does anyone have any idea on how to solve this?
Thanks in advance!
Best regards,
Bruno Seiva Martins
- Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
- Compilation error EPICS for RTEMS Bruno Seiva Martins
ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
<2012>
2025
<2012>
2025
