Subject: Re: CAC problem between RTEMS and vxWorks
To: Wesley Moore <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 21 Sep 2012 09:45:13 -0500
On 9/21/12 9:33 AM, Wesley Moore wrote:
> Jeff and Dirk - thanks for getting back to me.
> I'm familiar with some of the issues that you guys pointed out, they can definitely bite you.  While double-checking your suggestions I found that one of the channels that was being monitored came from another vxWorks IOC (mistake on my part).  Surprise, surprise...it never has any disconnect issues.  Following that lead, I found that the problems seem to be centered around a dynamically assigned pv in one of my two sequencers.  When I hard-coded that pv assignment the problems went away.  This remains consistent.  What's confusing me a bit is that I use dynamic assignment in the working sequencer, I just don't do any reassignments.
> Ben - Any known issues with dynamic assignment/reassignment?  Perhaps specific to RTEMS?
Hi, Wesley.
There have been a number of bug fixes related to pvAssign.  You
can find these in the release notes (just search in the page for
"pvAssign"):
  http://www-csr.bessy.de/control/SoftDist/sequencer/Notes.html
What version of the sequencer are you using?
Lewis
Re: CAC problem between RTEMS and vxWorks Wesley Moore
Prev: Re: CAC problem between RTEMS and vxWorks Wesley Moore
Next: Re: CAC problem between RTEMS and vxWorks Wesley Moore
