1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Problem with using strings to access enum indices on Windows
Cc: EPICS tech talk <[email protected]>, "'Gerry Swislow'" <[email protected]>
Date: Mon, 24 Sep 2012 10:45:48 -0500
On 9/24/12 10:10 AM, Mark Rivers wrote:
> One solution would be the following in dbFastLinkConv.c.
> #ifdef _WIN32
>   #define UNSIGNED_FORMAT " %u%n"
> #else
>   #define UNSIGNED_FORMAT " %u %n"
> #endif
>  nargs = sscanf(from,UNSIGNED_FORMAT,&ind,&nchars);
>  if(nargs==1 && nchars==strlen(from) && ind<nchoices) {
>    *pfield = ind;
>    return(0);
> This would preserve the current behavior on all platforms except _WIN32.  It would allow _WIN32 to correctly parse all strings except those with trailing whitespace, which is much better than the current situation where it fails for all strings that do NOT have trailing whitespace.
I think it's nicer if ifdefs can be avoided.  Another approach
might be to try using the "%c" format specifier to match just
one char.  Maybe it works correctly on Windows when preceded by
a space in the format string?
Or, there's also strtoul.  This will allow leading white space,
but you'd have to check the end pointer to allow trailing white
space (since with trailing white space it would not point to a
NUL char).
Lewis
Re: Problem with using strings to access enum indices on Windows Andrew Johnson
Problem with using strings to access enum indices on Windows Mark Rivers
RE: Problem with using strings to access enum indices on Windows Mark Rivers
Prev: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Next: Re: DHCP/BOOTP configuration for EPICS with RTEMS Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Problem with using strings to access enum indices on Windows Eric Norum
Next: Re: Problem with using strings to access enum indices on Windows Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
