1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Motor record -- URIP with soft limits
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Wed, 26 Sep 2012 10:21:17 +0000
The pmacAsynMotor driver doesn't know about the motor record UEIP or URIP fields, as these are just internal to the motor record. But the driver does set the 'encoder present' bit in the MSTA field, allowing the use of UEIP to switch between REP and RMP for the position readback.
We have the same problem with soft limits. We get around it in the same way (widening the limits, or setting them both to zero - which disables the soft limits).
Cheers,
Matt
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of J. Lewis Muir
> Sent: 25 September 2012 21:57
> To: Ernest L. Williams Jr.
> Cc: EPICS Techtalk
> Subject: Re: Motor record -- URIP with soft limits
> On 9/25/12 3:31 PM, Ernest L. Williams Jr. wrote:
> > On 09/25/2012 01:01 PM, J. Lewis Muir wrote:
> >> I've run into the same problem, but not using URIP.
> > Are you using "Use Encoder" ?
> > Seems to me that any of the "USE xxx" modes exhibit this problem.
> Both UEIP and URIP are set to No.  My DTYP is asynMotor.  And
> the driver implementing the asynMotor interface is pmacAsynMotor
> from tpmac 3-10 <http://www.gmca.anl.gov/TPMAC2/index.html>.
> So, yes an encoder is actually being used, but my guess is that
> the motor record UEIP and ERIP fields are ignored by the
> pmacAsynMotor driver.  (I haven't checked this.)
> >> My scenario
> >> is like yours: I can't move the motor because it is beyond one
> >> of the soft limits.  My workaround is to temporarily extend or
> >> disable the soft limits, move the motor back to a position
> >> within the original soft limits, and then restore the soft
> >> limits.
> > This is a manual operation that we don't operators to have to
> > deal with.
> > Of course, some sequencer could be written for automation.
> Right; in fact that's what I've done to automate the recovery.
> Lewis
Re: Motor record -- URIP with soft limits J. Lewis Muir
Motor record -- URIP with soft limits Fong, Nia W.
Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
Prev: RE: CAC problem between RTEMS and vxWorks Hill, Jeff
Next: Re: Motor record -- URIP with soft limits J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Motor record -- URIP with soft limits J. Lewis Muir
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
