1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: MKS937B Vacuum Gauge Controllers....
To: David Reid <[email protected]>
Date: Wed, 26 Sep 2012 19:31:57 -0700
Hi David,
I have StreamDevice support for the MKS 937A and MKS 937B controllers. I only did a bit of testing with the 937B in Emulation mode and I remember that our 937A support worked fine with it. There is a protocols bug in early versions of the 937B in 937B mode protocols where the response doesn't include "@"  as documented in the manual. I just deploy some newly received models where this has been fixed.
Your welcome to our StreamDevice support.
Hope that helps,
Matt
Matt Boyes
SLAC National Accelerator Laboratory
2575 Sand Hill Rd    MS 50
Menlo Park, CA 94025
[email protected]<mailto:[email protected]>
Phone: (650)926-5204
On Sep 26, 2012, at 4:59 PM, David Reid <[email protected]<mailto:[email protected]>> wrote:
Does anyone out there have any experience with MKS937B vacuum gauge controllers?  We have a couple that we have put into Emulation mode, and are communicating with using the MKS937A device support.  We are seeing the driver sending out a series of Write commands, with no response, and getting a flood of responses from the controller, and the device support is unable to handle that.
Thanks...
Dave Reid
Australian Synchrotron
MKS937B Vacuum Gauge Controllers.... David Reid
Prev: RE: MKS937B Vacuum Gauge Controllers.... Mark Rivers
Next: Block message when open cs-studio.sourceforge.net Juan.Guzman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
