1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Building a self-contained shareable library
To: "'Janet Anderson'" <[email protected]>, Andrew Johnson <[email protected]>
Date: Thu, 27 Sep 2012 15:27:12 +0000
Hi Janet,
Thanks, that worked!
This is very useful when building shareable libraries that we distribute to users without EPICS build systems.  The library is then completely self-contained and they don't need to install libCom.so, libezca.so, etc. somewhere and make the system find them at run-time with LD_LIBRARY_PATH or some other mechanism.
-----Original Message-----
Sent: Thursday, September 27, 2012 10:08 AM
To: Andrew Johnson
Cc: [email protected]; Mark Rivers
Subject: Re: Building a self-contained shareable library
You could try adding the following lines to the Makefile that creates the
shareable library.
SHARED_LIBRARIES = YES
STATIC_BUILD = YES
<libraryname>_LDFLAGS = $(STATIC_LDFLAGS)
On 09/26/2012 05:56 PM, Andrew Johnson wrote:
> Hi Mark,
> On 2012-09-26 Mark Rivers wrote:
>> I would like to build an EPICS shareable library on Linux that is
>> self-contained, i.e. it does not depend on any other shareable library.
>> For example, with IDL I would like libezcaIDL.so to not depend on
>> libca.so, libCom.so, libezca.so, and libEzcaScan.so.
>> But I am looking for a cleaner solution.  When EPICS is built with
>> SHARED_LIBRARIES=YES it actually builds both .a and .so files for every
>> library.  I would like a way to specify that ezcaIDL should be built as a
>> .so file, but it should be linked with .a files for everything it depends
>> on.
>> Is there a way to do this?
> You can change the command that we use to link a shared library by modifying
> the variable LINK.shrlib in your Makefile.  The value for this variable is set
> in one or more of the Base/configure/os/CONFIG.* files according to your
> platform.  For GNU-based platforms we actually use g++ to do the linking
> because it has to do more than the ld program normally does when linking C++
> code.
> Your replacement linker command should use the the -Wl,-Bstatic command-line
> option (or any of its synonyms which I won't list here) immediately before any
> -l options naming libraries that you want to statically link against, then -
> Wl,-Bdynamic (or its synonyms) before the -l options naming shared libraries.
> You'll probably want to run this manually to get the right combination.
> The EPICS build system doesn't have a way to do this automatically, and I
> think it would be rather complicated to try to make it do so.  Note that the
> resulting Makefile rule probably won't be portable; the above options apply to
> the GNU linker, you may have to adjust them for other platforms you want to
> use.
> HTH,
> - Andrew
Building a self-contained shareable library Mark Rivers
Re: Building a self-contained shareable library Andrew Johnson
Re: Building a self-contained shareable library Janet Anderson
Prev: Re: Building a self-contained shareable library Janet Anderson
Next: Re: How can I collect data values Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: MKS937B Vacuum Gauge Controllers.... David Reid
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
