Subject: Re: Triggered autosave on exit
To: Yong Hu <[email protected]>
Cc: "[email protected] talk" <[email protected]>
Date: Fri, 5 Oct 2012 10:06:10 -0700
The ALS uses a sub record:
record(sub,"$(IOC):exit") {
        field(DESC,"Exit subroutine")
        field(SCAN,"Passive")
        field(SNAM,"exitSubroutine")
with:
static void exitSubroutine(subRecord *precord) {
    epicsExit((precord->a == 0.0) ? EXIT_SUCCESS : EXIT_FAILURE);
epicsRegisterFunction (exitSubroutine);
Processing this causes the IOC to exit.
On Oct 5, 2012, at 9:42 AM, "Hu, Yong" <[email protected]> wrote:
> Franck's use case of the autosave is very interesting, but I guess it may take efforts to find the solution. I have tried different ways on Linux softioc:
> 1. I tried to add manual_save() to the xxxMain.cpp. Something like these:
>    iocsh(NULL);
>    manual_save("xxx.req");
>    epicsThreadSleep(2);
>    epicsExit(0);
> However, this will not work since manual_save() is only available in the autosave module and it is not included in the EPICS base.
> 2. I tried to use create_triggered_set() in the startup script file (st.cmd) just as Tim's suggestion. Also I used the devIocStats module which provides a PV named "yhuHost:SYSRESET" to reboot the IOC. Here are the configurations for st.cmd and db file:
> st.cmd:
>    create_monitor_set("auto_settings.req",30,"P=xxx:")
>    create_triggered_set("auto_settings.req","yhuHost:resetIOC","P=xxx:")
> db file:
>    record(bo,"yhuHost:resetIOC")
>        field(ZNAM,"NoRest")
>        field(ONAM,"Reset")
>        field(FLNK,"yhuHost:seqExample")
>    record(seq,"yhuHost:seqExample")
> 	  #delay 2 seconds to reboot the IOC
>        field(DLY1,"2")
>        field(LNK1,"yhuHost:SYSRESET.PROC ")
> When I do "caput yhuHost:resetIOC 1", the autosave is really executed (the save file "auto_settings.save" is written) and then about 2 seconds later, there is a message output "IOC reboot started" from the softioc. However, the IOC is not really rebooted, it is hung up (I still see the Shell "epics>").
> Any suggestion about my second approach? Any other better way?
> Thanks,
> Yong
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
> Sent: Friday, October 05, 2012 10:42 AM
> To: Tim Mooney; Di Maio Franck
> Cc: [email protected]
> Subject: RE: Triggered autosave on exit
> Can I have a PV that does that when I type "exit" on my softIoc?
> I agree that what Frank suggests would be very nice.
> Mark
Eric Norum
[email protected]
Triggered autosave on exit Di Maio Franck
Re: Triggered autosave on exit Tim Mooney
RE: Triggered autosave on exit Mark Rivers
RE: Triggered autosave on exit Hu, Yong
Prev: RE: Triggered autosave on exit Hu, Yong
Next: RE: Lambda-TDK Genesys support Szalata, Zenon M.
Next: Re: Triggered autosave on exit Tim Mooney
