1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Calcout using CA output link sometimes gets INVALID severity
Cc: [email protected]
Date: Fri, 12 Oct 2012 14:37:23 -0500
On 10/12/12 2:27 PM, Andrew Johnson wrote:
> Hi again Lewis,
> On 2012-10-12 J. Lewis Muir wrote:
>> In reality, this calcout thing is a bit contrived; I was just
>> creating a small test to show the problem.  What I really want
>> to do is to use the putNotify functionality that some extension
>> records use to wait for all records to finish processing as a
>> result of a put.  Examples of this are the sseq record
>> (WAIT[1-A] fields) in the std module, the scalcout record (WAIT
>> field) in the calc module, and the sscan record in the sscan
>> module.  All of these will have problems if processed before the
>> CA links are connected.
> FYI all the output record types in 3.14 have "Async Soft Channel" device
> support which use ca_put_callback() to provide that kind of wait-for-
> completion functionality.
Hi, Andrew.
Interesting--didn't know about that.  Thanks for the info!
> In 3.15 the input record types come with "Async Soft Channel" support for DB
> links, meaning that they process the record they're pointing to and wait for
> completion before returning the value from the addressed field.  Strangely
> though the output device support described above hasn't been changed to work
> using DB links yet, although it could use the same mechanism.
Thanks for this info too--didn't know about that either.
Lewis
Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
Re: Calcout using CA output link sometimes gets INVALID severity Ralph Lange
Re: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Prev: Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Next: Re: Calcout using CA output link sometimes gets INVALID severity Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
