new-host:base-3.14.12.2 jamesbryant$ export EPICS_BASE=/Users/jamesbryant/Desktop/base-3.14.12.2 new-host:base-3.14.12.2 jamesbryant$ python setup.py install python: can't open file 'setup.py': [Errno 2] No such file or directory
new-host:base-3.14.12.2 jamesbryant$ python3 setup.py install /Library/Frameworks/Python.framework/Versions/3.2/Resources/Python.app/Contents/MacOS/Python: can't open file 'setup.py': [Errno 2] No such file or directory
new-host:base-3.14.12.2 jamesbryant$ sudo setup.py install Password: sudo: setup.py: command not found # before this I input: new-host:base-3.14.12.2 jamesbryant$ export EPICS_HOST_ARCH=darwin-x86
new-host:base-3.14.12.2 jamesbryant$ make # ... and it spit out a bunch of code, which ended with: mkdir ../../../lib/perl/5.12.4 mkdir ../../../lib/perl/5.12.4/darwin-thread-multi-2level
Installing script ../../../bin/darwin-x86/cainfo.pl Installing script ../../../bin/darwin-x86/caput.pl Installing script ../../../bin/darwin-x86/caget.pl
Installing script ../../../bin/darwin-x86/capr.pl Installing script ../../../bin/darwin-x86/camonitor.pl rm -f CA.html podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
../CA.pm pod syntax OK. Installing html ../../../html/./CA.html rm CA.html any ideas??? - Thanks!
ANJ, 18 Nov 2013 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
