Subject: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12]
To: Janet Anderson <[email protected]>
Cc: "Shankar, Murali" <[email protected]>, EPICS Techtalk <[email protected]>
Date: Tue, 30 Oct 2012 08:51:58 -0700
Hi Janet,
How is it going?
For IOC Application deployment; I would like to take advantage of the $(INSTALL LOCATION).
The only problem is that IOC Startup files do not get installed along with other products such as databases, libraries, etc...
So, I tried to do something like the following:
In my  $IOC_APP_TOP/iocBoot/<iocName>
Create CONFIG_STARTUP:
CONFIG_STARTUP ========================
FILE_TYPE +=  STARTUP
INSTALL_EDL = $(INSTALL_LOCATION)/ioc/vioc-b34-cd39
Add to Makefile:
Makefile =====================================
TOP = ../..
include $(TOP)/configure/CONFIG
# Config for installing IOC startup related files:
CFG +=  CONFIG_STARTUP
ARCH = linuxRT-x86
TARGETS = envPaths
INSTALL_STARTUP += envPaths rtPrioritySetup.cmd st.cmd
include $(TOP)/configure/RULES
include $(TOP)/configure/RULES.ioc
The above does not work.
[ernesto@cdlx01 vioc-b34-cd39]$ make
/afs/slac/g/lcls/epics/base/base-R3-14-12/configure/RULES_DIRS:72: *** target file `clean' has both : and :: entries.  Stop.
Can you recommend a way to achieve this in the context of the EPICS Make/Build system?
Cheers,
Ernest
Re: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Ralph Lange
Prev: Re: CSR/CR questions Bjorklund, Eric A
Next: Re: waveform record: how its VAL get data? any potential memory leak? ... Jack Smith
Next: Re: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Ralph Lange
