Subject: vdct and info tags
Date: Fri, 02 Nov 2012 12:06:11 -0400
Looking in the list archives I find a message from 2009 which I interpret to mean that VDCT will preserve info() tags which are added manually.
http://www.aps.anl.gov/epics/tech-talk/2009/msg00876.php
Cosylab has upgraded VDCT, starting with v2.6, so that the info field is kept after resaving a VDCT file, using VDCT, that has info fields included.
However, I have empirical evidence that this is not the case for VDCT version 2.6.1274. This is the latest version according to the Cosylab page.
http://visualdct.cosylab.com/builds/VisualDCT/
The tag I add is
info( autosaveFields_pass0, "VAL")
Then I start VDCT and make a change to an unrelated record. When saved, the info() tag is absent. I've tried several variation on the quoting, but this has no effect. I see nothing printed to the console and no log message appear.
Does this work for anyone?
Michael
Re: vdct and info tags Ralph Lange
Prev: RE: Runaway connection count on IOC -- Possible Gateway Issue? Hill, Jeff
Next: Re: vdct and info tags Ralph Lange
Prev: Re: Bug in iocLogServer Andrew Johnson
