1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Please down the post. \ if possible
Date: Sat, 3 Nov 2012 00:16:32 +0000
Subject:
rtems running on Altera nios2
sungil kwon <[email protected]>
To:
[email protected]
Date:
Fri, 2 Nov 2012 16:48:08 -0600
I am working on running rtems on the altera nios2.
I tested network-4-10-demos.
The netdemo example was  working.
Now I am trying to test tftpClient exmaple.
My host is RHEL5.
The following is the message though I slightly modified the original program init.c
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 6-1]", device 1, instance 1
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Free space 66115176
bootpc_init: using network interface 'tse0'
boSotpc hw address is 0:7:ed:ff:49:0
My ip address  is 128 .165 .32 .154
Domain Name Server is 128 .165 .1 .1
Time Server is 128 .165 .1 .1
Ignoring BOOTP/DHCP option code 44
Domain name is lanl.gov
Subnet mask is 255 .255 .255 .0
Server ip address is 128 .165 .32 .156
Gateway ip address is 0 .0 .0 .0
Log server ip address is 128 .165 .32 .156
bootpc_Nadjust_interface: add net route, error=114
Destination     Gateway/Mask/Hw    Flags     Refs     Use Expire Interface
128.165.32.0    255.255
 niitn et.255.0      U           0        0      9 tse0
TFTP mounted successfully ~~~~~~~!
host path is ------->: /TFTP/128.165.32.156/mytftp/test.txt
!!!!  TFTP remote FILE SYSTEM initialization OK !!!!!
fp  is  ((null)), and errno is 12
Open failed: Not enough space
Please help me.
Prev: rtems running on Altera nios2 sungil kwon
Next: Re: User Created File Types: FILE TYPE += ABC [EPICS R3-14-12] Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Device support for the Agilent (HP) 33120A waveform generator Pavel Maslov
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
