Subject: Re: Problems sending \x0 with devGpib driver
To: Dirk Zimoch <[email protected]>
Cc: Eric Norum <[email protected]>, Andrew Wagner <[email protected]>, [email protected]
Date: Thu, 08 Nov 2012 09:17:18 -0600
On 11/8/2012 7:50 AM, Dirk Zimoch wrote:
Do not use devGpib for any new project!
I find that devGpib with the GPIBCVTIO function has be able to solve erratic communication problems that streams has been unable to deal with. Case in point is with a Kalmus IF-488 device were the error message would be inserted at any point in the reply (readback) string. Using Streams I could not devise a return string argument that would capture all the possible error messages embedded in a normal reply string. But , using the GPIBCVTIO function I was able to write a single function that parsed out all possible error messages from any command and flag it appropriately.
Currently I'm in the middle of writing a Streams support for a LM-500 Cryogenic Liquid Level Monitor but have discovered that this device will get out of sync with it reply messages, that is part of a reply is in one string while the other half is in another reply string. I'm seriously considering starting over to use the GPIBCVTIO function to clean this up.
I like Streams for the ease of creating a quick device support but have found it difficult for devices that do not have a robust command interface. This could be the lack of ingenuity on my part to create a complex reply argument in Streams which devGpib seems to overcome this short coming of mine.
So, for me, devGpib will always be considered on new projects.
Nick
RE: Problems sending \x0 with devGpib driver peter.owens
Re: Problems sending \x0 with devGpib driver Dirk Zimoch
Problems sending \x0 with devGpib driver Andrew Wagner
Re: Problems sending \x0 with devGpib driver Eric Norum
Re: Problems sending \x0 with devGpib driver Andrew Wagner
Prev: Re: Problems sending \x0 with devGpib driver Dirk Zimoch
Next: RE: Problems sending \x0 with devGpib driver peter.owens
