Subject: Re: StreamDevice and sCalcoutRecord.h
To: [email protected]
Date: Thu, 15 Nov 2012 16:48:41 +0100
On 15.11.2012 11:12, Pavel Maslov wrote:
When I try to compile StreamDevice (ASYN 4-16, base 3.14.12,
StreamDevice 2-4, 2-5), I get the following error. What's wrong? Any ideas?
//usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -MMD -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
  -I/home/operator/applications/epics/modules/asyn/include
-I/home/operator/applications/epics/base/include/os/Linux
../devscalcoutStream.c/
/../devscalcoutStream.c:21:28: warning: sCalcoutRecord.h: No such file
or directory/
Hello Pavel,
sCalcout is an optional record from SynApps. If you don't have SynApps installed, you can skip the whole srcSynApps subtree of StreamDevice.
I thought that I had a mechanism in the srcSynApps/Makefile that compiles the stuff only if SynApps is installed, but maybe there is something wrong there. I will check this.
Dirk
Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
StreamDevice and sCalcoutRecord.h Pavel Maslov
Prev: Re: archive data server James F Ross
Next: Re: Long string support in CA clients and device support J. Lewis Muir
Prev: Re: StreamDevice and sCalcoutRecord.h Tim Mooney
Next: Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
