Subject: caRepeater object code not cross-compiled in R3.14.12.2
To: EPICS Tech Talk <[email protected]>
Date: Wed, 21 Nov 2012 09:57:19 -0800
Hi all.
Did I do something wrong?
My $EPICS_HOST_ARCH is linux-x86. I've added to
configure/os/CONFIG_SITE.linux-x86.Common the line:
CROSS_COMPILER_TARGET_ARCHS = linux-arm
In configure/os/CONFIG_SITE.linux-x86.linux-arm, I've set $GNU_DIR &
$GNU_TARGET to identify the name and location of my cross toolchain.
The build completes normally, and in bin/linux-arm I see a small number
of channel access tools, as well as a script to launch caRepeater, but
no caRepeater binaries. The tools built for the cross-compiled
architecture seem to work normally. My target architecture is a full-on
Linux host, which may run multiple IOC applications, and should be using
caRepeater.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: caRepeater object code not cross-compiled in R3.14.12.2 Dirk Zimoch
Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
Prev: RE: asynPortDriver epicsMutex error Mark Rivers
Next: Re: 3.14 v.s. 3.15 vs. v4 Jack Smith
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Dirk Zimoch
