Subject: posix osiSpawnDetachedProcess inherits scheduling policy + priority
To: EPICS Techtalk <[email protected]>
Date: Mon, 26 Nov 2012 16:56:32 -0600
The current implementation of posix/osiSpawnDetachedProcess()
basically just forks and execs. The new process inherits the
scheduling policy and priority of whoever called spawnDetachedProcess().
This means e.g., that a caRepeater spawned by a "real-time enabled"
IOC application executes under SCHED_FIFO with priority 51.
Not sure this is a good thing. IMO osiSpawnDetachedProcess()
should be fixed so that the new process starts out with SCHED_OTHER.
- Till
Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Andrew Johnson
Prev: Re: Error building asyn4-20 on CentOS 6.3 Andre Charbonneau
Next: Re: Problem with medmfonts.ali running under Ubuntu 1204 Ivan Kohler
Prev: compiling EPICS Channel Archiver using epics.4.14.7 on 32 bit scientific linux James F Ross
Next: Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Andrew Johnson
