Subject: RE: Using CAJ in production
To: <[email protected]>, <[email protected]>
Date: Thu, 29 Nov 2012 18:36:08 +0000
Hi Shankar,
On Diamond Beamlines our primary EPICS client is GDA, which uses the CAJ pure Java CA client. However, if I understand you correctly, they
·         probably don’t monitor PV’s with DBE_PROPERTY through a CA gateway.
·         they don’t use CA Access Security
I am not sure about the issue with EPICS_CA_MAX_ARRAY_BYTES, but they do get and monitor large arrays.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
From: [email protected] [mailto:[email protected]] On Behalf Of Shankar, Murali
Sent: 29 November 2012 18:30
To: '[email protected]'
Subject: Using CAJ in production
Just wanting to check if anyone uses CAJ (pure Java CA client) clients in production especially in combination with IOC's that are using the native CA library.
I've pinged a few folks offline; however, it was thought that a community wide repoll would probably be beneficial.
Known issues that I am already aware of (thanks Michael and Eric)
1) Interoperability issue with the CA Gateway and clients using monitors with DBE_PROPERTY.
2) For CA Access Security, CAJ uses full hostnames (with domain) and libca uses short host names (without domain)
3) The issue with EPICS_CA_MAX_ARRAY_BYTES  has already been fixed.
Has anyone encountered any issues/differences on the IOC side?
Murali
Using CAJ in production Shankar, Murali
Prev: Using CAJ in production Shankar, Murali
Next: Using CSS and setting up RDB Archiver James F Ross
Next: Re: Using CAJ in production Pelaia II, Tom
