Subject: RE: Tektronix 3014 IOC Errors
To: Trevor Downer <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 30 Nov 2012 03:12:24 +0000
Hi Trevor,
I'm assuming 10.1.1.1. is the correct IP address?
Have you tried uncommenting the line:
#TDS3000Reboot $(ETHER)
The error is coming from this code in drvVxi11.c:
    clntStat = clnt_call(pvxiPort->rpcClient, create_link,
        (xdrproc_t)xdr_Create_LinkParms,(caddr_t)&crLinkP,
        (xdrproc_t)xdr_Create_LinkResp, (caddr_t)&crLinkR,
        pvxiPort->vxiRpcTimeout);
    if(clntStat != RPC_SUCCESS) {
        asynPrint(pasynUser,ASYN_TRACE_ERROR,
            "%s vxiCreateDeviceLink RPC error %s\n",
            devName,clnt_sperror(pvxiPort->rpcClient,""));
    } else if(crLinkR.error != VXI_OK) {
            "%s vxiCreateDeviceLink error %s\n",
            devName,vxiError(crLinkR.error));
From: [email protected] [[email protected]] on behalf of Trevor Downer [[email protected]]
Sent: Thursday, November 29, 2012 7:07 PM
To: [email protected]
Subject: Tektronix 3014 IOC Errors
Greetings and salutations!
I am new to this whole EPICS thing and am running into a problem while
trying to connect my EPICS server to the Tektronix 3014 Oscilloscope
using the ethernet port on the oscilloscope.
The specific setup is below:
computer (ethernet cable) > switch (ethernet cable) > oscilloscope
We decided to isolate our setup from our schools network by running
the ethernet cable through a simple switch.
By doing this we were able to ping the oscilloscope successfully.
I downloaded the software for the oscilloscope application from
http://www.aps.anl.gov/epics/modules/instrument/tds3000/index.html the
Module Version is R2-4. Everything in configure/RELEASE is correct to
my knowledge. However we keep getting lots of errors!
The first error that I noticed is "2012/11/29 17:51:39.058 inst0
vxiCreateDeviceLink error VXI: invalid address" and I have no idea
what that means!
The full output from the IOC is below:
scope.physics.isu.edu[155]# ./st.cmd
#!../../bin/linux-x86/scope
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocscope")
epicsEnvSet("TOP","/home/scope/oscope/tds3000-2.4")
epicsEnvSet("SNCSEQ","/usr/local/epics/extensions/src/synApps_5_6/support/seq-2-1-10")
epicsEnvSet("ASYN","/usr/local/epics/extensions/src/synApps_5_6/support/asyn-4-20")
epicsEnvSet("STREAM","/usr/local/epics/extensions/src/synApps_5_6/support/stream-2-5-1")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base-3.14.12.2")
< envParams
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 100000
# Site-specific configuration
epicsEnvSet(FAMILY, "3000") # Choose scope family (3000 or 5000)
#epicsEnvSet(ETHER, "$(TDS_ETHERNET=10.0.0.1)") # Choose scope ethernet address
epicsEnvSet(ETHER, "10.1.1.1") # Choose scope ethernet address
epicsEnvSet(SCOPE, "scopeTest:") # Choose scope ethernet address
# Ensure that we can transfer a complete waveform
epicsEnvSet(EPICS_CA_MAX_ARRAY_BYTES, 100000)
cd /home/scope/oscope/tds3000-2.4
dbLoadDatabase("dbd/scope.dbd")
scope_registerRecordDeviceDriver(pdbbase)
## Load diagnostic record instance
dbLoadRecords("db/asynRecord.db","P=scopeTest:,R=,PORT=L0,ADDR=3,OMAX=0,IMAX=0")
## Load oscilloscope db's if using Auto Print/Re-arm trig SNL program.
dbLoadRecords("db/scopeMessage.vdb","scope=scopeTest:,L=0,A=3,ASG=RF1CTL,rfsys=1")
## This is the main db.
dbLoadRecords("db/TDSxxxx.vdb","scope=scopeTest:,L=0,A=3,ASG=RF1CTL,Name=RF1-HV,FAMILY=3000")
# reboot scopes (Ethernet only)
#TDS3000Reboot 164.54.xxx.xxx
#epicsThreadSleep(60)
## Set up IOC/hardware links -- GPIB/LAN connection
#vxi11Configure("L0", "$(ETHER)", 0, 0.0, "hpib", 0)
## Set up IOC/hardware links -- Direct network connection
vxi11Configure("L0", "10.1.1.1", 0, 0.0, "inst0", 0)
2012/11/29 17:51:39.058 inst0 vxiCreateDeviceLink error VXI: invalid address
2012/11/29 17:51:39.096 inst0 vxiCreateDeviceLink error VXI: invalid address
2012/11/29 17:51:39.097 L0 -1 autoConnect could not connect
## Set up IOC/hardware links -- Remote serial port
## (link, host, priority, noAutoConnect, noEosProcessing)
#drvAsynIPPortConfigure("L0", "$(ETHER)", 0, 0, 0)
#asynOctetSetInputEos("L0",0,"\n")
#asynOctetSetOutputEos("L0",0,"\n")
## Set up IOC/hardware links -- Local serial port
## (link, ttyName, priority, noAutoConnect, noEosProcessing)
#drvAsynSerialPortConfigure("L0", "/dev/ttyS0", 0, 0, 0)
#asynSetOption("L0", 0, "baud", "38400")
#asynSetOption("L0", 0, "bits", "8")
#asynSetOption("L0", 0, "parity", "none")
#asynSetOption("L0", 0, "stop", "1")
#asynSetOption("L0", 0, "clocal", "N")
#asynSetOption("L0", 0, "crtscts", "Y")
## Turn on all diagnostic messages to stdout
#asynSetTraceMask("L0", -1, 0x9)
#asynSetTraceIOMask("L0", -1, 0x2)
#asynSetTraceIOTruncateSize("L0", -1, 120)
## Start IOC
cd /home/scope/oscope/tds3000-2.4/iocBoot/iocscope
iocInit()
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Nov 16 2012
2012/11/29 17:51:39.534 scopeTest:: queueRequest failed
2012/11/29 17:51:40.035 scopeTest:clearMenuBO queueRequest failed port
L0 not connected
2012/11/29 17:51:40.035 scopeTest:frontPanelLockBO queueRequest failed
port L0 not connected
2012/11/29 17:51:40.035 scopeTest:ethernetNameSI queueRequest failed
2012/11/29 17:51:40.036 scopeTest:initBO queueRequest failed port L0
not connected
## Start any sequence programs
#seq scopeAutoArmPrint,"scope=$(SCOPE)"
epics> 2012/11/29 17:51:40.535 scopeTest:scopeBusyBI queueRequest
failed port L0 not connected
2012/11/29 17:51:41.035 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:41.535 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:42.035 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:42.535 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:43.035 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:43.535 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:44.035 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:44.535 scopeTest:acquireStatBI queueRequest failed
2012/11/29 17:51:44.535 scopeTest:triggerStateMI queueRequest failed
2012/11/29 17:51:44.535 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan1CoupleMI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan2CoupleMI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan3CoupleMI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan4CoupleMI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan1VdivMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan2VdivMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan3VdivMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan4VdivMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:timeModeMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:timeRefAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:trigSourMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:trigSlopeMI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan1_ImpedBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan2_ImpedBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan3_ImpedBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan4_ImpedBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan1VdivAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan2VdivAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan3VdivAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan4VdivAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan1OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan2OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan3OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan4OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:trigLevAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:holdoffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:timeBaseAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:timeDelayAI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.031 scopeTest:chan1EnableBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan2EnableBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan3EnableBI queueRequest failed
2012/11/29 17:51:45.031 scopeTest:chan4EnableBI queueRequest failed
2012/11/29 17:51:45.036 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:45.536 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:46.036 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:46.536 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan1EnableBO queueRequest failed
2012/11/29 17:51:47.027 scopeTest:chan2EnableBO queueRequest failed
2012/11/29 17:51:47.027 scopeTest:chan3EnableBO queueRequest failed
2012/11/29 17:51:47.027 scopeTest:chan4EnableBO queueRequest failed
2012/11/29 17:51:47.027 scopeTest:chan1OffAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan1OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan2OffAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan2OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan3OffAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan3OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan4OffAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:chan4OffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:trigLevAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:trigLevAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:holdoffAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:holdoffAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:timeDelayAO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:timeDelayAI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:trigSlopeMI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:trigSlopeMO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:trigSourMI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:trigSourMO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:timeModeMI queueRequest failed port
L0 not connected
2012/11/29 17:51:47.027 scopeTest:timeModeMO queueRequest failed port
L0 not connected
2012/11/29 17:51:47.036 scopeTest:scopeBusyBI queueRequest failed port
L0 not connected
I would greatly appreciate any help in resolving this issue.
Tektronix 3014 IOC Errors Trevor Downer
Prev: Tektronix 3014 IOC Errors Trevor Downer
Next: CSS BOY left-mouse event Mogamad Amien Crombie
