Subject: Re: Using CSS and setting up RDB Archiver
Date: Fri, 30 Nov 2012 14:11:58 -0500
I seem to be missing some necessary files for the RDB archiver to run properly.  I get the following errors when trying to run org.csstudio.archiver.engine/ArchiveEngine.product (see below).  I found org.eclipse.equinox.http.jetty8 in the eclipse equinox repository and downloaded it, but I'm still getting the error.  Perhaps I needed more than just that one package?  Any help would be appreciated.
Thank you!
James
!SESSION 2012-11-30 13:56:59.962 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_37
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product org.csstudio.archive.engine.engine
Command-line arguments:  -product org.csstudio.archive.engine.engine -data /home/sysuser/CSS/cssTest/css-nsls2/workspace/../runtime-ArchiveEngine.product -dev file:/home/sysuser/CSS/cssTest/css-nsls2/workspace/.metadata/.plugins/org.eclipse.pde.core/ArchiveEngine.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2012-11-30 13:57:00.518
!MESSAGE Product org.csstudio.archive.engine.engine could not be found.
!ENTRY org.eclipse.osgi 2 0 2012-11-30 13:57:00.551
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.551
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841.jar was not resolved.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.551
!MESSAGE Missing imported package org.eclipse.jetty.util.component_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.552
!MESSAGE Missing imported package org.eclipse.jetty.server.nio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.util.log_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.553
!MESSAGE Missing imported package org.eclipse.jetty.io.nio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.handler_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.554
!MESSAGE Missing imported package org.eclipse.jetty.server.ssl_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.bio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.session_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.servlet_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.555
!MESSAGE Missing imported package org.eclipse.jetty.util_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.http_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.io.bio_[8.0.0,9.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.555
!MESSAGE Bundle initial@reference:file:../../../home/sysuser/CSS/cssTest/css-nsls2/plugins/org.csstudio.archive.rdb_3.1.1.201211061437.jar was not resolved.
!SUBENTRY 2 org.csstudio.archive.rdb 2 0 2012-11-30 13:57:00.555
!MESSAGE Missing required bundle org.eclipse.help_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2012-11-30 13:57:00.566
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.566
!MESSAGE Bundle org.csstudio.utility.httpd_1.0.0.qualifier [3] was not resolved.
!SUBENTRY 2 org.csstudio.utility.httpd 2 0 2012-11-30 13:57:00.566
!MESSAGE Missing required bundle org.eclipse.equinox.http.jetty_0.0.0.
!MESSAGE Bundle org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [23] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.566
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.567
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.568
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.568
!MESSAGE Bundle org.csstudio.archive.config.rdb_1.0.0.qualifier [24] was not resolved.
!SUBENTRY 2 org.csstudio.archive.config.rdb 2 0 2012-11-30 13:57:00.568
!MESSAGE Missing required bundle org.csstudio.archive.rdb_3.0.1.
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.569
!MESSAGE Bundle org.csstudio.archive.rdb_3.1.1.201211061437 [26] was not resolved.
!SUBENTRY 2 org.csstudio.archive.rdb 2 0 2012-11-30 13:57:00.569
!MESSAGE Bundle org.csstudio.archive.writer.rdb_1.0.0.qualifier [28] was not resolved.
!SUBENTRY 2 org.csstudio.archive.writer.rdb 2 0 2012-11-30 13:57:00.570
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.572
!MESSAGE Bundle org.csstudio.archive.engine_3.0.1.qualifier [31] was not resolved.
!SUBENTRY 2 org.csstudio.archive.engine 2 0 2012-11-30 13:57:00.573
!MESSAGE Missing required bundle org.csstudio.utility.httpd_1.0.0.
!ENTRY org.eclipse.osgi 4 0 2012-11-30 13:57:00.573
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
    at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
    at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
On Thu, Nov 29, 2012 at 4:02 PM, Kasemir, Kay <[email protected]> wrote:
For the record, turned out to be the tool.
The *.product file won't open in CSS itself nor in a plain JEE version of Eclipse.
-Kay
From: James F Ross <[email protected]<mailto:[email protected]>>
Date: Thursday, November 29, 2012 16:01
To: Kasemir Kay <[email protected]<mailto:[email protected]>>
There we go.  It looks like I had the wrong version of eclipse installed.  It is opening .product properly now with eclipse 3.7.0 for RCP/RAP development.
Thanks very much!
James
On Thu, Nov 29, 2012 at 1:45 PM, Kasemir, Kay <[email protected]<mailto:[email protected]>> wrote:
Hi:
>The issue is, when I open the .product file it should open the eclipse product editor window, allowing me to synchronize and launch the eclipse application.  >However, all it does when I double click on it is open the file, displaying the source code.
Do you have the Eclipse 3.7(.2) IDE for RCP/RAP development, and in there you're trying to open the product file?
Then maybe you have once opened it as a text file, so you'll have to right-click on the product file and select Open With.../Product editor to make it default to the product editor again.
For more detail than in the Jlab wiki see http://cs-studio.sourceforge.net/docbook/css_book.pdf
-Kay
Re: Using CSS and setting up RDB Archiver Kasemir, Kay
Prev: DBE_PROPERTY and CSS Re: Using CAJ in production (DBE_PROPERTY and CA gateway) Kasemir, Kay
Next: EPICS support for NewFocus 8752 controller? Fairley, Diane M.
Prev: Re: Using CSS and setting up RDB Archiver Kasemir, Kay
Next: Re: Using CSS and setting up RDB Archiver Kasemir, Kay
