Subject: Re: mask for bitwise operation in CALC record
To: haquin <[email protected]>
Date: Mon, 3 Dec 2012 12:57:31 -0600
Hi Christophe,
On 2012-12-03 haquin wrote:
> I have seen on the website 3.15.0.1 release available, is it reliable ?
Base releases numbered 3.15.0.n should not be used in production systems, they
have not undergone widespread testing.
> If not, have you more visibility on when 3.15.1 will be released ?
Not really, it depends on the community, although I have heard ITER say that
they'd like it by the end of next year to be able to use it in their 2014
Codac core system release.
> If not soon, could this be patched in 3.14.12.2 ?
I have just added code to allow use of hex literals in CALC expressions to the
3.14 branch (back-ported from the 3.15 version), so this will appear in the
3.14.12.3 release which is due out before Christmas.
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
Re: mask for bitwise operation in CALC record haquin
Re: mask for bitwise operation in CALC record Andrew Johnson
Prev: Re: Using CAJ in production Andrew Johnson
Next: Re: Using CSS and setting up RDB Archiver James F Ross
Prev: Re: mask for bitwise operation in CALC record haquin
Next: Re: mask for bitwise operation in CALC record haquin
