Subject: RE: Initializing starting position on a Motor
To: "'Tonia Batten'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 4 Dec 2012 22:58:12 +0000
Are you using the EPICS autosave module to save your motor positions?  If so, then when you restart EPICS it should restore the previous position automatically.  The motor record actually does the following logic:
-          If the controller position at EPICS startup is non-zero it uses the controller position
-          If the controller position at EPICS startup is 0 it uses the autosaved position
What is causing the motor to move at the end of initialization?  That does not normally happen.
From: [email protected] [mailto:[email protected]] On Behalf Of Tonia Batten
Sent: Tuesday, December 04, 2012 4:52 PM
To: [email protected]
Subject: Initializing starting position on a Motor
Good Afternoon,
I am new to EPICS and am working on creating a motor controller for the PI E517 motor.  I am using EPICS R3.14.12 and Motor 6.5 I have got the device communicating and am able to perform the necessary commands but have run into a problem with initialization.  The problem is that when I restart my EPICS application I might be in the middle of a scan and therefore I don’t want the motor to change its current position (ideally I don’t want to have to move the motor to the same position).  At the moment when I restart the application the motor is returning to a zero position.   I suspect that I am not initializing the DVAL field correctly in the MOTOR record, but have not been able to confirm as the motor is moved as soon as the initialization is complete and before I can monitor.   Any feedback or direction would be greatly appreciated.
Tonia Batten, P.Eng
Control System Analyst
Canadian Light Source
44 Innovation Blvd.
Saskatoon, SK S7N 2V3
Tel:  306-657-3865
Email: [email protected]
RE: Initializing starting position on a Motor matthew.pearson
RE: Initializing starting position on a Motor Tonia Batten
Prev: Initializing starting position on a Motor Tonia Batten
Next: Registering DBD files and iocshRegisterCommon michael.abbott
Next: RE: Initializing starting position on a Motor matthew.pearson
