Perhaps the reason of such behavior is the EPICS_CA_MAX_ARRAY_BYTES env. variable. Try to increase it to say 20000 or thereabouts.
On Fri, Dec 7, 2012 at 1:29 AM, Eric Norum <[email protected]> wrote: It sounds like you have two problems. Generating an SDDS file is a separate issue from displaying waveforms in the MEDM window. Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01
ANJ, 18 Nov 2013 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
