1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Tektronix 3014 Tracing Problem
To: "Nicholas P. DiMonte" <[email protected]>, Trevor Downer <[email protected]>
Cc: Yoojong Kim <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Dec 2012 14:17:40 +0000
His screen shots don't look like a Windows machine, they look like a Fedora machine I think.
From: [email protected] [[email protected]] on behalf of Nicholas P. DiMonte [[email protected]]
Sent: Friday, December 07, 2012 8:11 AM
To: Trevor Downer
Cc: Yoojong Kim; [email protected]
Subject: Re: Tektronix 3014 Tracing Problem
Trevor,
There are two separate issues that you are dealing with. The SDDS script needs the SDDS package installed to display the waveforms and is not needed for the MEDM display. I added these SDDS scripts to produce a cleaner and more detail display of the plots for our technicians here at the APS, I included them as an example only. Sorry for the confusion.
The MEDM display issues may be that EPICS_CA_MAX_ARRAY_BYTES environment variable is not set high enough. This variable needs to be set on both the IOC and on the computer your using. For the TDS3000 at 10k record size, you will needed to set this variable to 80000 to accommodate the waveform being a "float" data type. The updated release for this support will have the option of selecting between 10k and 500 data points, which means this variable could be set as low as 20000.
I'm not an expert when it comes to running EPICS on a Windows machine, but the blue section in the MEDM display looks like it might be a EPICS_CA_MAX_ARRAY_BYTES environment variable issue. On a UNIX/Linux system I would see four black squares, one for each waveform, but they would be all blank if this variable is set to low. The blue section I see in your post is the back ground color I chose for this section, so I'm puzzled as to why the "Cartesian Plot" objects are not visible, maybe it a Windows thing. Window experts please respond.
On a side note, I will be releasing a long over due update to this support by February, which has improvements to reliability issues with the TDS3000 series and enhanced waveform handling for the TDS5000 series. Also, a clarification on the use of the SDDS utilities has been updated.
Keep me updated so I can add this issue to the new release.
Nick D.
On 12/6/2012 6:00 PM, Trevor Downer wrote:
Greetings and salutations!
I am a student at Idaho State University working on a project to
control a Tektronix 3014 oscilloscope, using EPICS, for the Idaho
Accelerator Center.
We have successfully installed EPICS and the necessary extensions to
communicate with the TDS3014 oscilloscope. Using medm we cannot see
the waveform tracings, we can however see the tracings from a web
browser, however its refresh rate is quite slow.
There seems to be a problem when I click on the SDDS Plot button, medm
outputs a message in the terminal reading:
"medm/trace10k: line 8: [: T: integer expression expected
 Usage: trace [1-4][HV or LL]<CR>\n"
 Attached is a screen shot of the traceless oscilloscope in medm and
the trace10k file where there seems to be a problem.
I would greatly appreciate any help to fixing the tracing problem,
thank you very much!
-Trevor Downer
RE: Tektronix 3014 Tracing Problem Yujong Kim
Tektronix 3014 Tracing Problem Trevor Downer
Re: Tektronix 3014 Tracing Problem Nicholas P. DiMonte
Prev: Re: Tektronix 3014 Tracing Problem Nicholas P. DiMonte
Next: RE: Tektronix 3014 Tracing Problem Yujong Kim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
