Subject: RE: Re:RE: "Connection refused" when running Ethernet/RS232 application
To: "'???'" <[email protected]>
Date: Thu, 13 Dec 2012 15:51:36 +0000
If telnet to that TCP port does not work then EPICS won’t work.  The fact that you can ping just means that the device exists.
Are you sure that port 1 is correct?  On the devices I have used the first serial port is typically TCP port 2001 or 4001.
Sent: Thursday, December 13, 2012 7:49 AM
To: Mark Rivers
Cc: 'Nicholas P. DiMonte'; tech-talk
Subject: Re:RE: "Connection refused" when running Ethernet/RS232 application
When I use “telnet” from my Linux machine:
  telnet 192.168.0.21 1
I also get connection refused. But “ping 192.168.0.21”, it works well.
I can’t find the “TCP Server Mode” attribute of the port of the NI Ethernet/RS232 convertor(4 ports) , and the port likely needn’t to be configured.
Then, Is the port number the convertor’s port num or the device port in the machine? how should I set the port number in drvAsynIPPortConfigure?
"Connection refused" when running Ethernet/RS232 application 张德敏
Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
Re:RE: "Connection refused" when running Ethernet/RS232 application 张德敏
Prev: EPICSPVFactory in CSS JavaScript Hovanes Egiyan
Next: RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
Prev: Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
Next: EPICS SIMULINK interface Klotz Wolf-Dieter
