Subject: How to access menu choice strings inside record support
Date: Thu, 13 Dec 2012 12:12:06 -0800
I am writing a custom record to deal with a particular hardware.  This
hardware has a few different operation modes, which are represented
with a set of name strings, not numbers.  We can talk to it to get or set this
mode, with strings.
The problem is, when a choice is made, we get a menu choice number.
Then I will need to find the corresponding name string, to write to the
hardware; on the other direction, when I query the hardware to find its
current mode, I get back a string.  Then I need to find the corresponding
choice number to set the button properly.
All these name strings are defined in the menu definition.  How can I
access them inside the record support?  Without having to declare
an array of strings, beside the menu definition?
Thanks much for your advices!  Best regards,
Dehong
Re: How to access menu choice strings inside record support Till Straumann
Re: How to access menu choice strings inside record support Andrew Johnson
Prev: RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
Next: Re: How to access menu choice strings inside record support Till Straumann
