Subject: Re: [makefile] adding a library to an EPICS application
To: [email protected]
Date: Thu, 20 Dec 2012 09:45:48 +0100
> In general I recommend making use of the EPICS build system if you
> can because we take care of things like creating dependency files and
> handling multiple architecture builds from the same source tree; most
> other build systems need you to do extra work for that kind of
> thing.
Of course Andrew is right. Someone has to spend some time to write the
EPICS specific rules. But in case of CMake most of this work has been
done already (see the links in my first mail).
Building for multiple architectures comes for free with CMake as it
supports out-of-source builds (actually they are default).
Cross-building is possible as well. It's supported with many different
tool chains. Of course you can add your own tool chain as well.
Creating dependency files should be an easy exercise but I think you
don't need them with CMake (it takes care of things like that
automatically). With Make it's difficult to write build rules that work
for parallel builds (e.g. make -j 4) with CMake it's difficult to write
rules that do not.
So I would still recommend using CMake for apps/libs that build on top
of EPICS base.
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
Re: [makefile] adding a library to an EPICS application Pavel Maslov
RE: [makefile] adding a library to an EPICS application Mark Rivers
Re: [makefile] adding a library to an EPICS application Andrew Johnson
Prev: RE: SNL with C Mark Rivers
Next: Re: [makefile] adding a library to an EPICS application Pavel Maslov
Prev: Re: [makefile] adding a library to an EPICS application Andrew Johnson
