1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: time drift in camonitor timestamps
To: [email protected]
Date: Tue, 8 Jan 2013 12:14:17 -0600
Hi Inari,
On 2013-01-08 inari badillo wrote:
> The magnitude of the error is about 700 microsecond (average), no matter
> the SCAN value is. So, it takes about 24min to have a 1s error.
> Answering Michael Davidsaver´s question, I mean precessing relative to the
> start time. The different does not increase every cycle. Sorry if it wasn´t
> clear.
> And finally yes, it seems reasonable to be caused by processing time. But
> in this case, wouldn´t it lead to malfunction?
The scan code does compensate for the time it takes to process the records in
its chain, but it doesn't try to correct for the time difference between when
the thread asked to be woken up and when the OS actually woke it up, and I
think that is the source of your 700us delay.
After adding some code to measure that delay on my workstation (RHEL 6.3 on a
Dual-Core 1GHz AMD Opteron) I have seen varying delays between -60us and
+230us, but nothing quite as big as 700us; my average is around 30-50us.
I will look at merging Eric's patch, or something like it (thanks Eric!).
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
time drift in camonitor timestamps ibadillo
Re: time drift in camonitor timestamps inari badillo
Prev: Re: time drift in camonitor timestamps Eric Norum
Next: UDT Instruments model 531(Optical Position Monitor) support ? Ivashkevych, Oksana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: time drift in camonitor timestamps Andrew Johnson
Next: Re: streamDevice: how to read a value as fast as possible? Dirk Zimoch
