1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm build
To: [email protected]
Date: Thu, 10 Jan 2013 10:18:11 -0600
Kate, Hinko,
On 2013-01-10 Hinko Kocevar wrote:
> ln -snf /usr/lib/i386-linux-gnu/libXt.a /usr/lib/libXt.a
On 01/10/2013 04:18 AM, Kate Feng wrote:
> ln -f -s /usr/lib/.../libxt.a libXt.a
It should /never/ be necessary to create soft-links like that, you just have
to edit your extensions/configure/CONFIG_SITE file or if you're sharing a
build tree between multiple architectures the appropriate
extensions/configure/os/CONFIG_SITE.<arch>.<arch> files to tell the build
system where the relevant libraries can be found.  Once you have correctly set
the X11_LIB and/or MOTIF_LIB variables (and the _INC variables if necessary)
for one product (say medm) it is then correct for any other products (say
StripTool) that you build in the same extensions tree.
This should be the more friendly solution that Hinko was asking for.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: medm build keith . thorne
medm build D Peter Siddons
Re: medm build Kate Feng
Re: medm build Hinko Kocevar
Prev: Re: acalcOut Pavel Maslov
Next: duplicating process variables James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: medm build Hinko Kocevar
Next: Re: medm build keith . thorne
