1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [CSS] FileUtil
To: Pavel Maslov <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 15 Jan 2013 08:42:48 -0500
Hi Pavel,
In BOY script, you can use the standard Python or Java code to read/write file. The problem is that you cannot directly work with workspace path. You need to call FileUtil.workspacePathToSysPath(String) to convert a workspace path to system file path.
Cheers,
Xihui
Sent: Tuesday, January 15, 2013 2:32 AM
To: EPICS Tech Talk
Subject: [CSS] FileUtil
Is there an opportunity to implement the binary read/write file functionality to the class FileUtil in CSS BOY?
I can only see the writeTextFile() and readTextFile() functions in this API.
Or there may be another way to read/write a binary file in CSS BOY?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
[CSS] FileUtil Pavel Maslov
Prev: EPICS Spring Collaboration Meeting Pre-meeting events austen.rose
Next: Re: problem about edm widget Jason Abernathy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [CSS] FileUtil Pavel Maslov
Next: sequencer release 2.1.11 Benjamin Franksen
