James,
Here's one possibility: By default, a sequencer program won't actually start running for real until every PV it connects to has connected. (See compiler option "+c".) You won't get an error message in this case. You can check the status of PV connections with the "seqChanShow" command. (See http://www-csr.bessy.de/control/SoftDist/sequencer/Using.html#examining-the-program) Tim From: "James F Ross" <[email protected]> To: "Mark Rivers" <[email protected]> Cc: "Jiro Fujita" <[email protected]>, "EPICS Tech Talk" <[email protected]> Sent: Tuesday, January 22, 2013 2:31:02 PM Subject: Re: sequencer programs in an IOC Thanks guys, Yes, the c code is not the problem. There was a communication issue that I knew was causing problems. That is fixed now, and I am getting a few of the desired html files written, but for some reason the main file is not being written. It seems to be going running the program relating to the eemc (one of the early ones called by a seq command in the st.cmd file) but never moves on to the program after it. There is no indication of error, but I'm looking at both the eemc source code and the bemc code (the next program called in the st.cmd file). James On Tue, Jan 22, 2013 at 3:19 PM, Mark Rivers <[email protected]> wrote: I would go a step further and say that the C code should be "transparent". It is created in the O.$(ARCH) directory from the .stt code, and is then immediately compiler to an object file to be linked into your application.
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
