I don't believe that I am running devIocStats. It is running a very old version of epics: 3.13.10. Do you happen to know if this is compatible with devIocStats? If so, and I install it, would it require changes to the source code or just to the db files to include a memory PV?
Thanks! James
On Mon, Jan 28, 2013 at 11:34 AM, Tim Mooney <[email protected]> wrote:
Hi James, Are you running devIocStats? http://www.slac.stanford.edu/grp/cd/soft/epics/site/devIocStats/
If so, memory is available as a PV whose value you could record in any number of ways. Tim
From: "James F Ross" <[email protected]> To: "EPICS Tech Talk" <[email protected]>
Sent: Monday, January 28, 2013 10:18:52 AM Subject: memory and vxWorks based IOCs
Hello everyone, I suppose this is more a vxWorks question than an epics question, but here is the issue.
I've got a VME based IOC running here at STAR that is having memory problems. Basically we noticed this issue as every 24-48 hours the IOC would lose communication and all GUIs associated with it would go blank. The solution is to re-start the IOC by rebooting the VME, but doing this every day is not a good solution.
The epics is running on vxWorks, so I can use the memShow command to show the memory usage at a given time. I can see that as I open more and more GUIs, the memory fills up. At least part of the cause of the loss of communication has to do with too many people opening GUIs relating to this IOC at the same time. However, I am not certain that this is the only problem.
What I would like is to track the memory usage over time to see if there is a time component as well as just too many GUIs being opened. Does anyone know how to do this in vxWorks? Get it to print its memory usage every minute or so to a log file or something similar?
Thanks James
- Re: memory and vxWorks based IOCs Paul Sichta
- memory and vxWorks based IOCs James F Ross
- Re: memory and vxWorks based IOCs Tim Mooney
Re: unable to tunnel CA through ssh tunnel Till Straumann
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
