1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory and vxWorks based IOCs
To: James F Ross <[email protected]>
Date: Tue, 29 Jan 2013 15:56:14 -0500
James,
Im may case I was able to rename the PVs on the VME IOC. Then in a soft IOC on a linux I put records which had the old known names but fetched/put their data from/to the renamed VME IOC PVs.
If you were to use an EPICS Gateway you would move the VME IOC to another subnet (so it is no longer visible on your EPIC subnet) and add another network interface to a machine on your EPICS subnet. You could then run an EPICS Gateway on this machine which would serve the shielded PVs onto your regular EPICS subnet. The Gateway is simple to build and configure.
John
On 01/29/2013 03:00 PM, James F Ross wrote:
Thanks all for the responses!
I'm planning on trying to limit memory usage, eventually instituting an
online version of the GUI so that people can go there if they just want
to check the values rather than opening new GUIs.
I'll also look into using a gateway on one of our linux machines. Does
the gateway just keep the variable values updated from the IOC, while
everything (GUIs, caget, etc) gets the values from the gateway? How did
you (John) set that up for the MVME 162? Mine is a 167 but it should be
useable in at least a similar way.
Thanks!
James
On Tue, Jan 29, 2013 at 2:49 PM, John Dobbins <[email protected]
<mailto:[email protected]>> wrote:
    James,
    At one point I had a similar problem. I had an IOC running on a
    MVMVE162 CPU with 4 Megs. It ran fine but as clients connected it
    ran out of memory. In that case I was able to arrange to serve those
    PVs through a gateway running on a Linux machine. The load the VME
    CPU was small and constant.
    John Dobbins
    On 01/29/2013 02:39 PM, Mark Rivers wrote:
        Depending on the model of your CPU card you may be able to buy a
        memory
        upgrade on the used market. I recently upgraded all of our
        MVME2700 CPUs
        from 32MB to 64MB. That will increase their useful lifetime
        significantly, since we were coming close to running out of
        memory with
        32GB on our beamline IOCs. It cost about $600 per card, which is
        a lot
        of money for 64MB of memory today, but is a lot cheaper than a
        new CPU card.
        [mailto:tech-talk-bounces@aps.__anl.gov
        <mailto:[email protected]>] *On Behalf Of *James F Ross
        *Sent:* Monday, January 28, 2013 10:19 AM
        *To:* EPICS Tech Talk
        *Subject:* memory and vxWorks based IOCs
        Hello everyone,
        I suppose this is more a vxWorks question than an epics
        question, but
        here is the issue.
        I've got a VME based IOC running here at STAR that is having memory
        problems. Basically we noticed this issue as every 24-48 hours
        the IOC
        would lose communication and all GUIs associated with it would
        go blank.
        The solution is to re-start the IOC by rebooting the VME, but
        doing this
        every day is not a good solution.
        The epics is running on vxWorks, so I can use the memShow command to
        show the memory usage at a given time. I can see that as I open
        more and
        more GUIs, the memory fills up. At least part of the cause of
        the loss
        of communication has to do with too many people opening GUIs
        relating to
        this IOC at the same time. However, I am not certain that this
        is the
        only problem.
        What I would like is to track the memory usage over time to see
        if there
        is a time component as well as just too many GUIs being opened. Does
        anyone know how to do this in vxWorks? Get it to print its
        memory usage
        every minute or so to a log file or something similar?
        Thanks
        James
memory and vxWorks based IOCs James F Ross
RE: memory and vxWorks based IOCs Mark Rivers
Re: memory and vxWorks based IOCs John Dobbins
Re: memory and vxWorks based IOCs James F Ross
Prev: Re: memory and vxWorks based IOCs James F Ross
Next: Re: copying archived data from 32-bit to 64-bit machine Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: memory and vxWorks based IOCs Jeong Han Lee
